Interior Constant 12V Source
Old Sep 6, 2011 | 06:46 AM
Harzley's Avatar
Default Interior Constant 12V Source
I'm installing a new head unit. The old one used the factory constant 12V, but the wire is rather small. I'm hoping to find a good place to hook up inside the car without going directly to the battery, but if there is nothing to be found I'm not against it.
Has anyone found a good place inside the car to hook up a constant 12V?
Old Sep 6, 2011 | 08:59 AM
varia's Avatar
cigar lighter
Old Sep 6, 2011 | 09:01 AM
Harzley's Avatar
Not a bad thought. Know what size fuse is on that circuit? How big is the wire?
Old Sep 6, 2011 | 09:31 AM
GuyllFyre's Avatar
18AWG and 15A fuse.
Old Sep 6, 2011 | 11:54 PM
ur20v's Avatar
Is this for a B3 or B4? Not 100% sure about B4's, but I know in the B3's there are two +12v sources under the drivers side dash. It's been a while since I hve been under one, but there are three plastic distribution blocks with brass spade lugs - one red, one yellow and one black. They are modular and snap into each other. Again, it's been a long time, but I think the yellow is constant and the red is switched, though that could be reversed. I awlays grab them whenever I come across them at the junkyard because they come in handy! If I had any here at the house I'd snap a photo for you, but they're at the shop.
Old Sep 7, 2011 | 05:52 AM
Harzley's Avatar
It is a B3. Are they attached to the large relay block under there? I know I've seen a yellow block just hanging out there. I'm really hoping to find a circuit around 20-30 amps with 14 AWG.
Old Sep 7, 2011 | 06:56 AM
GuyllFyre's Avatar
Any head unit drawing 20-30A isn't going to want to be installed in a dash due to heat build-up and failure.
Been there, done that, t-shirt says don't do it.
Old Sep 7, 2011 | 07:00 AM
Harzley's Avatar
Understood. I don't expect it to be drawing that much just covering myself especially since it will likely piggy-back off another circuit.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 7, 2011 | 07:02 AM
GuyllFyre's Avatar
Check to see what the head unit requires. Many have their own fuse that's only 7.5A or 10A, so not much to worry about in terms of draw.
dS8
Sep 5, 2008 01:26 PM
GDawgA4
Dec 3, 2007 02:45 PM
90v8quattro
9
Nov 7, 2007 08:20 AM
mroberts
9
Mar 14, 2003 12:51 PM
kk_1.8t
Sep 21, 2002 05:42 AM
