07 S8 Adaptive cruise inop - ACC doesn't work after Radar replace - vag com
I have attached the Vag-Com readings.
New S8 owner
new to the forum
New Vag-Com user
Sunday,04,September,2011,19:54:04:24956
VCDS Version: Beta 11.8.0 (x64)
Data version: 20110831
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1E 34 36
37 38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44E07N015671 Mileage: 94320km/58607miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 5AH15--- Serial number: AUX3Z0G0714671
Coding: 01060009190F0260
Shop #: WSC 22133 444 59012
VCID: 2045E6348DD9
2 Faults Found:
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 94326 km
Time Indication: 0
Date: 2011.09.04
Time: 19:50:47
Freeze Frame:
RPM: 639 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 53.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
001153 - Coolant Fan Control Circuit 2: Electrical Malfunction
P0481 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 94326 km
Time Indication: 0
Date: 2011.09.04
Time: 19:50:47
Freeze Frame:
RPM: 645 /min
Load: 22.7 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 53.0°C
Voltage: 13.716 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01--- Serial number: 0100803
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2B5F0118F41F
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 244DEA2499C1
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G0714671
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B50ED41509
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 244DEA2499C1
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348AM077509303
Coding: 0000003
VCID: 2241EC3C83D5
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000113143
Coding: 0041409
VCID: 1C3DD2C4A1B1
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133123
VCID: 3669206C3F5D
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000034
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 2757FD28E8F7
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0047758
Shop #: WSC 00000 000 00000
VCID: 2C5D0204F111
Address 11: Engine II Labels: Redir Fail!
VCID: 2045E6348DD9
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 B HW: 4E0 907 561 B
Component: ABSTANDSREGELUNG X140
Coding: 0041118
VCID: 2143E33086D3
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 88
Mileage: 94324 km
Time Indication: 0
Date: 2011.09.04
Time: 19:52:00
Freeze Frame:
Temperature: 40.0°C
Voltage: 13.70 V
Bin. Bits: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0037Q0G01MSH
Coding: 0532707
VCID: 2649F02CEFFD
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012151
VCID: E5CB3720527B
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 981 A HW: 4E0 920 981 A
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G0000129
Coding: 0048263
Shop #: WSC 22133 444 58922
VCID: 2649F02CEFFD
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4E0 907 468 G
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0100J07104811D
Coding: F5D5DFFF717A0E
VCID: ECDD4204B191
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3148614
VCID: 1835CED45589
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A51041CFBE5
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
VCID: 244DEA2499C1
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381AI077517051
Shop #: WSC 22133 444 54118
VCID: 38752E543549
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No: 4E0 910 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000634500181
Coding: 0003479
VCID: 1D3BDFC0BAAB
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 2045E6348DD9
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040701230429
Coding: 0048702
VCID: 2A51041CFBE5
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 C HW: 4E0 035 466
Component: BO_D3 H06 0310
Revision: 20S00002 Serial number: 02112060007522
Coding: 0000026
VCID: 2649F02CEFFD
Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000004519
Coding: 0010111
VCID: 1E39D8CCB7AD
Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
VCID: 2045E6348DD9
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000732
VCID: 2045E6348DD9
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Time Indication: 0
Freeze Frame:
Voltage: 9.11 V
Count: 61
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2953FB10FEE3
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396A/077558575
Coding: 0000002
VCID: 2E59080CC70D
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000029251
VCID: 2045E6348DD9
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0701230131
Coding: 344530393135313035412056413030373031323330313331
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
VCID: 1E39D8CCB7AD
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900049442
Coding: 0232428
VCID: 2045E6348DD9
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 88
Mileage: 94326 km
Time Indication: 0
Date: 2011.09.04
Time: 19:54:11
Freeze Frame:
(no units): 0.0
Temperature: 27.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000701230045
Shop #: WSC 12336 024 394758
VCID: 346D1A642921
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J71103B
Coding: 1121402
VCID: DCBD12C46131
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
VCID: 1E39D8CCB7AD
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720701800321
Coding: 0221208
VCID: 234FE9389CCF
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007563359
Coding: 0010900
VCID: 2855FE14E5E9
End ---------------------------------------------------------------------
A lot of these errors seem unrelated. I would pull the fuses and look for any breaks. Same for the wiring harness in the bumper, though it's probably hard to access. Then I would clear the codes with VCDS and immediately run the program again to make sure everything comes up clean before starting the car. Then I would drive around a bit, run the program again and see what comes back. If it's exactly the same pattern then they are interrelated and you may have to ask an Audi tech to figure it out.
Good luck and let us know what happened.
