whining noise from rear of car and rough idle
also my wife said she heard the whining noise get louder when I put it in park, that made me thing transmission, but when I rev the car the noise doesn't change.
are fuel pumps common on these cars?
I have 115000 km
and yes they do have 2 fuel pumps, nothing new dual pumps have been used since the mid 80s in big German sedans, we all know back then Audi was nowhere near that field.
any idea how to check the pressure at the pumps?
one easy way to see if they work is disconnecting one first while the engine is running and see if the engine change speed or dies, if no difference plug it back and unplug the second one, if it dies while doing this you have a dead pump.
The faultcode comes up ONLY after engine braking for a longer period of time at low rpm and high gear, ie. slowing down from 80km/h.
Had some trouble with the passenger side FRONT lambda connectors, created faultcodes on the lambda sensors 1&2 on "pumping", but was corrected with just inspecting the connectors. The fault there also came up while engine braking.
Wondering, are the two fuel rails connected together, or why would the failure of one pump affect just the idle the most?
No rough idle here... tough could a W12 have a rough idle...
And if you put mine on "tipronic" like 4-6gear and do a pull at low revs the engine "shakes" roughly. Does this sound like the fuel pump, i think it does?
Can you buy the pumps separately from audi, or just the whole tank system as usual that costs like 5000 euros (at minimum) here (already the floor mats are 350euros
)Or then i'll just replace the pumpus by a bosch replacement part. No need to replace my volvo S90 -98 fuel pump with 300000km on the clock...
I suspect it's the prolonged fuel filter change intervals on newer cars that clogs up the filter, and then destroys the pump, when the pump has to work harder to get gas trough the filter.
The S90 has an filter change interval of 60000km, while newer cars i've changed filters on have a 160000 interval. No need to repace pumps on ord RWD volvos before 300000km, but the newer cars need the pump&filter replaced @ 150-160000km (changed many).
