How to pull fault codes?
http://20v.org/fault.htm
and have been disappointed with three different shops, you are coming around to the idea that perhaps you are going to have to fix it. "Seems like"? Where you expecting to do that with just mouse clicks?
The same frustration you feel drove others to both find out how and build that site. Are you up to that challenge?
The above site may also help you with your rough starting diagnosis if you will but use it. Often those kind of symptoms can be the result of something like a simple leak of un-metered air into the intake tract. Because that air is not measured by the air meter, the appropriate fuel is not dispensed to mix with it, which can result in rough starting/running. 20v.org and this site with the search function will glean you many places to look for leaks, dirty ISVs, deteriorated vacuum and crankcase vent lines etc.
These usual suspects are a good place to start because their condition must be assured, and fixing them is simple and cheap.
Consider that if you find such tasks daunting, what are your alternatives? You have a car that is potentially great, if you don't learn how to get it there, you might never know how good it can be.
These cars are not cherished by the lucky few without good reason.
