rear differential bearing replacement
usually is the front pinion shaft bearing the noisy one, but you won't know until taken apart.
not that hard to do depending who you ask, in an average it cost 1400.00 to replace them all.
If one of the the bearings on the pinion is a problem, then you will want to carefully measure pinion depth, which does take some special gauges, as otherwise the pinion and ring gear mesh won't be quite right, and you will end up with more noise than you started with.
I've just looked at the ETKA parts listing, and at least from what I can see, Audi doesn't list the parts that go inside the differential, only the complete unit. Seems like the dealers are more into 'replace the unit' rather than 'replace the part that's bad inside the unit'. By the time labor charges are considered, probably more economical to just but the complete differential and bolt it in.
