88 90 q Tie Rods
Old Oct 7, 2011 | 09:07 PM
88a90q's Avatar
Default 88 90 q Tie Rods
I need the part # for the tie rods. The VIN # split for this car is killing me. If I wasn't on the wrong side of it I would have no problems finding suspension parts but I am so it's almost impossible to find ball joints and tie rods that have big enough shafts. So anyone else haveing this trouble or was mine the only one? There is a dirty joke in there somewhere but I really could use the help though.
Old Oct 7, 2011 | 09:24 PM
varia's Avatar
post the VIN or a pic of the actual set up.
Old Oct 8, 2011 | 08:42 AM
88a90q's Avatar
vin is WAUHC0896JA228459
Old Oct 8, 2011 | 02:38 PM
88a90q's Avatar
Ok so I was wrong tie rods are the same for all 88 90s and others too I am sure. So I got the right ones problem is I cannot get the outer end off the inner.
Old Oct 8, 2011 | 02:44 PM
88a90q's Avatar
In trying to loosen the nut touching the tie rod end the inside end(threaded, bare) came out of the inner tie rod. I cannot put this back on the car now because the peice that I am holding in the one pic rotates with the nut. So that option is out my question is can I get the threaded part somewhere so I don't have to try and replace the whole tie rod looks reall hard to get at inner bolt with tools.
Old Oct 8, 2011 | 02:48 PM
88a90q's Avatar
I can put the threaded part back in the car but won't be able to wrench the nut down on the tir rod end(part that I am holding). It turns freely
Old Oct 10, 2011 | 07:57 AM
Bruch's Avatar
Don't be afraid....those two bolts holding the inner ends of the tie rods to the steering rack unit are not as difficult as they look. You need a couple variations of 17mm wrenches to get at them. I think maybe easier from underneath. You should have poly-lock nuts there, so it becomes tedious having to wrench them all the way off.
Look at a picture on the EKTA parts list. If I recall correctly, you take the nuts off the tie rod ens, then you still have to remove the vertical nuts/bolts from the steering rack end to get it apart.
Remember, your can move the work to an ideal spot by turning the steering wheel one way or the other.
Good luck
QuattroProject90
Feb 24, 2009 08:02 AM
egp320i
Jan 18, 2008 11:50 AM
TwentyValveB5+S4
Feb 27, 2005 08:29 PM
Ghostfire
Feb 20, 2004 02:29 PM
