1988 audi 90 water pump help.
Old Oct 23, 2011 | 06:20 AM
dcc0011's Avatar
Default 1988 audi 90 water pump help.
I am the proud owner of a 1988 audi 90. The water pump started to weep so I'm looking at replacing the harmonic balancer along with tensioner and timing belt. I found a kit from Blauparts.com. They ask if the timing belt is square or round tooth. I'm guessing mine is square but how do I tell without taking the front clip off?
Also the heater core was leaking and is now bypassed. I was looking at pulling the dash out but looks like a real pain in the ***! I saw this new stuff called K-Seal and was thinking maybe I could use that. I even thought of circulating it only through the heater core and then flushing. I would use a turkey fryer and a drill pump. Also block the discharge a little to up the pressure. It sure would be a good test of the product that's for sure.
Thank you all who offer opinions. I love the internet!
Old Oct 23, 2011 | 06:21 AM
dcc0011's Avatar
also, this is the 10v 5 cylinder. thanx again!
Old Oct 24, 2011 | 04:56 PM
dcc0011's Avatar
ok, der, found the sight hole. Square tooth. I read the crank bolt is 350 lbs. So I need a 350 lb. torque wrench? Can I cheat that and just put it back on roughneck tight or does it have to be that exact 350? I can get a 30" breaker and a swamper and put an easy 600 on it if I have to. Or would 200 and some blue lock tight do the job? maybe just jump on the breaker bar a couple times. I'm 150 on a 30" lever would be what? gotta be somewhere close to 350 right?
Old Oct 24, 2011 | 05:26 PM
varia's Avatar
http://www.sears.com/shc/s/s_10153_1...Origin%7CSears
http://www.harborfreight.com/catalog...ultsPerPage=27
Old Oct 24, 2011 | 05:39 PM
dcc0011's Avatar
Thank you very much for the links. No torque wrench there goes to 350 lbs. I don't want to spend $150 on this! Maybe I'll just poor boy it and rent one from autozone. eeeeeek! does this have to be 350 exact? can I just go over tight here or do I "HAVE" to use a torque wrench to get 350 exact? Sorry to be such a worm, I'm running on unemployment at the moment. Thank you for any help here.
Old Oct 25, 2011 | 07:28 AM
varia's Avatar
I think its 350Nm and not 350lbs, the metric (SI) unit of torque is the newton metre (Nm). In inch units, torque is usually measured as Lb-Ft (pounds feet) or Lb-In (pounds inch).
Old Oct 25, 2011 | 03:35 PM
one5k's Avatar
just crank it on tight by hand with a breaker bar. mine never fell off and also none of the cars i've ever seen in the dealer i work at either. just make sure its tight. maybe a little bit of locktite. just keep an eye on it for a few days after. you will be fine.
Old Oct 25, 2011 | 05:12 PM
dcc0011's Avatar
Thank you very much. That is what I wanted to hear! Anyone else think I'm gonna bugger it up by over tightening it?? Blue lock tight?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 28, 2011 | 09:47 AM
dcc0011's Avatar
OK. Job done. Thank you very much AudiWorld for the guide that I followed. Helped a lot! My crankshaft seal was bonded to the engine. I will need to do it again and possibly mill out the seal with a rotozip or a dremel and a lot of time. When I replaced it I put a pin in a drill and tweaked the tip a just a bit to router out the old seal but all I get to is metal. Has anyone else ran into this. It's like the aluminum inside the seal boded to my engine!!! I mangled the new seal trying to pound it in but I have no leaks. Is this even something I should worry about?
TSTARKS77
Aug 13, 2012 03:55 PM
jimmyTT01
10
Oct 31, 2005 11:06 AM
tbrent
Sep 24, 2004 03:58 PM
NHAudi90
Feb 7, 2003 07:36 AM
Laurie
Audi 100 / A6 (C4 Platform)
15
Jan 9, 2003 10:50 AM
