Brake BT: Best way to drain Brake fluid from Reservoir?
In an ideal world, we empty that old fluid (often dirty) via suction, refill with clean fluid and then pressurize/bleed with the MOTIVE. I'm not keen on forcing that dirty fluid thru the brake system if I don't have to.
I would need to see if they even offer a new filter to the point if you did break it out you could replace it but I doubt it. It is most likely integrated into a new reservoir as one piece.
Some master cylinders did have a bleeder on them I have read. I have one on mine but it looks to be welded solid so I did not bother to even try.
