Groan from Right Front at low speed - Common?
Good luck
I took it in, and they said it was the tensioner pulley bearing. I plan to change the timing belt in about 5k, and they said it's safe to drive until then, so I'm waiting.
Take note of a couple of things:
-does it change in pitch as a function of speed or RPM?
Mine does not change with speed, only RPM.
If it changes with speed and not RPM (obviously they are not unrelated), then assume wheel bearing or tires.
If it changes with RPM, then it's probably something before the transmission.
At first I thought it might be a differential, but after realizing it didn't change with speed, the dealer's tensioner pulley diagnosis seemed plausible.
