How do I pull my ECU?
all accessories off and remove key then disconnected battery.
removed lower cover,
pull the wiring harness little bit (makes longer)
then loose clip with "L" shaped screw driver (hand made tool)
pulling housing of connector down while pushing the clip to harness side with special tool ( very hard to release this clip)
removed lower holding clip on ECM
then pull down the ECM ( not easy )
ECM #?
To Install, reverse removal procedure. good luck. x19
