Rear Diff Seal Removal Help
I am in the process of removing the drivers side rear diff seal and removed the 6 triple square bolts from the diff and now trying to remove the half shaft from the diff? Is the something else you have to remove or loosen or is it suppose to just slide out? I loosened the diff, but still no luck. Car is a 94 90 b4. Thanks in advance!
search feature is very useful btw
http://www.audizine.com/forum/showth...al-replacement
