pulling the climate control panel
Old Nov 6, 2011 | 11:18 AM
maseraudi's Avatar
Default pulling the climate control panel
Dear all, I have searched the forum for a while but could not find help concerning how to pull the manual control panel without breaking the commands . I have a replacement panel but I need to save the 3 control commands from the old panel. Thanks for your help
Fred
Old Nov 9, 2011 | 01:21 PM
maseraudi's Avatar
Default How to check trans fluid level?
Oh and also , I think I am leaking trans fluid...How do I check the level?
Thanks
FB
Old Nov 9, 2011 | 03:16 PM
Luxus Panzer's Avatar
Fred
Manual CC in a B4?
If so... put a rag over the dial to protect the plastic from the players and use pliers to pull the *** straight out. Take note of ***** position before you remove them so you can put them back on in the same position.
I would turn them all all the way to the right or left before removal to keep it simple.
you will then see 3 screws that need to come out. the wood trim, you just pry it off carefully and it should expose anything else that needs to be removed.
Old Nov 9, 2011 | 03:17 PM
Thanks
FB
Auto or Manual Tranny?
Old Nov 10, 2011 | 07:06 AM
maseraudi's Avatar
Default Sorry, I have an auto tranny.
Thanks for the help, I really appreciate it. I did not buy this car for too much money but I had to fix few issues during Spring 2011 (shot axles and suspensions, gas leak) and the bills are piling up. The engine is only 85K and runs strong, the tranny pulls fine, it's just after driving home from work, I smell a strong fluid smell and from time to time a small puddle on the garage floor: but all accessible fluid levels are checking out? My mechanic change the trans fluid at the same time he did the other jobs...
Old Nov 10, 2011 | 06:27 PM
if it is an auto...you have a dipstick for tranny fluid. I suggest you read your user manual
ArmyMD
Audi A3 / S3 / RS 3
Jan 22, 2019 01:54 PM
furiousgtz
Jul 2, 2015 04:33 AM
zeems
Mar 23, 2006 09:20 PM
big_anthoiny
Jun 2, 2004 11:09 AM
das
Jul 9, 2001 07:07 PM
