Lago Blue.... I need info on the spring "isolators" you made
Old Nov 25, 2011 | 09:07 AM
Luxus Panzer's Avatar
Default Lago Blue.... I need info on the spring "isolators" you made
I remember you made "insulators" for the bottom spring perch on one of you B4's out of some kind of mud flap at CT.
I was just wondering if you could post or email me some info on this so I can attempt to make my own.
Thanks.
Z.
Old Nov 25, 2011 | 04:45 PM
Andy1212's Avatar
I have been planning on getting these next time i feel motivated to take apart the suspension (again grr)
http://www.energysuspension.com/univ...isolators.html
Old Dec 15, 2011 | 08:12 AM
Lago Blue's Avatar
Default Re: Isolators...
I looked at those too before I built mine, and I won't say that they can't work, but after seeing the landscape that they have to fit into, I decided that there may be a problem fitting them as they are perfectly round; and our perches are not.
I still suspect that the amount of experiment time and trimming required to fashion them into something that would:
a.) stay put;
b.) survive the energy input long-term; &
c.) provide the desired benefits...
satisfactorily would have made me wish I had started with a clean sheet of paper and just some raw material. So that is what I did. However as I did not try that route, I would welcome any news of other approaches, should one so choose.
When I was done, my isolators resembled an example of something you might find to indicate a musical score, or some odd print type font. They are "round", but only in a manner of speaking.
Our springs and perches have "pig-tails" towards the insides, as opposed to the commercial isolators, which appear to be fashioned for springs without pig-tails, where the spring wire is first cut and then ground flat so that the spring will stand perfectly vertical on a plain flat surface. Not so ours.
Our springs, which can be made to work perfectly well and silently, exhibit noise, force, wear and movement characteristics that are particular to their pig-tail features that are certainly different than what I expected to find.
I was able to buy a very good MacPherson Strut/Spring Compression Tool second hand, which greatly eased the work load of the hundreds(?) of times I have had the suspension out.
I don't think one can really know how good an otherwise OEM suspension can be until you have incorporated isolators on your main suspension springs.
Previously:
https://www.audiworld.com/forums/sho...ight=suspended
Old Dec 21, 2011 | 06:59 PM
Andy1212's Avatar
Great post Lago, thanks! Thats good to know about the isolators I posted, I didnt even think about that coil indentation our spring perches have.
tree580
Jul 26, 2007 03:21 PM
ajp_984
Jun 11, 2003 07:53 PM
lefTTy
Jul 30, 2002 09:55 AM
hater
Oct 16, 2001 06:34 AM
JeeRS
Apr 12, 2000 04:50 PM
