Rear brakes doing most of the braking...
My reasoning is as follows:
1. When cleaning the car, there is a lot of brake dust on the rear wheels and little to none on the front.
2. I have warped two sets of rear rotors in the past year and have had to replace my rear brake pads before the fronts.
3. With the warped rear rotors I can feel the car lurch with the rotation of the wheels as it comes to a stop (slow speeds).
Can anyone enlighten me as to what the problem might be? I'm kinda tired of going through rotors at this point and am worried about wet/snowy handling.
Thanks,
Chuck
Try putting the car on a level surface, and (carefully!) leave it in neutral with the e-brake off and jack up each corner. Spin the wheels by hand and see if the rears seem harder to spin than the front. If so, the problem might be one (or several) of the things I mention above. If the rears spin as easily as the fronts, maybe it's a difference between pads F and R?
If you have time, bleed the brakes, relube the pins, and check that pistons are moving freely.
You will need special brake tool that can be borrowed from pepboys/autozone to push rear pistons back in.
Pull the pins out and re-lube and make sure they rotate freely once inserted.
I find myself doing this once a year to make sure they move ever since I had a pin on my right side become frozen solid forcing me to buy a new carrier.
It does sound like your pads are riding on the rotor.
Do you have the same brand of pads front and back? Some pads are naturally dusty and some are not.
I used PBR metal masters for years but have since switched to EBC ultimax pads which are much much better and also cost less.
Pagid,Mintex and Textar are dusty, two other popular brands.
The pads are different in the rears as I just replaced them (no idea what they were originally), so it is possible that they are just more dusty - hadn't thought about that.
One way to check the fronts is to simply remove the caliper, string it up and push on the pedal to see if the piston moves out. A pair of C clamp vise grips works great to push the piston back in if you don't have the actual tool.
