Alignment Specifications for '95 90Q Sport
Old Nov 28, 2011 | 02:16 PM
sonnigentag's Avatar
Default Alignment Specifications for '95 90Q Sport
Hi Audi peers,
Steering wheel leans slightly to the right when car is going straight. There are no vibrations. I have replaced ball joints and tires since last alignment. Taking it to the Subaru dealer to have it aligned, then local shops don't seem to have the technical capacity be able to work on it. [nearest Audi dealer is 2 hrs away]
Would anyone happen to have the alignment specifications for a '95 90 Quattro Sport?
This is what I have found so far, but it is for '93 CS Quattro. I was thinking that with the rear suspension being lower on the sport, the specs would differ.
http://tech.bentleypublishers.com/th...ssageID=325387
Old Nov 28, 2011 | 02:30 PM
kakarot1232001's Avatar
numbers look good. Toe eats tires, so 0 is good will be weird to drive a little, so 1/3deg . I run -1 deg camber up front. Follow the specs, should end up fine. Unless you race, then need different specs.
Old Nov 28, 2011 | 04:22 PM
Great info, thanks kakarot. From the Sears alignment sheet, my total front toe is out of spec at .17 degrees [toe-in]. Now I know what to look at. Thanks once more.
simonyun
May 2, 2007 07:01 AM
Joey T
Jan 26, 2006 01:46 PM
Gold A4 QT
Mar 23, 2002 06:13 PM
Ted-Bob
Apr 3, 2001 07:00 AM
RodF
Wheels & Tires Discussion
Jun 10, 1999 08:25 AM
