CampioniShop: Forgestar 2012 collection - Year round specials
About Forgestar Performance Wheels:
Introducing the World's 1st 1 piece lightweight flow formed wheel lineup.
1 piece flow formed wheels
Lightweight
Clears big brake kit
Great range of offsets
Same Technology Used on Formula 1 and Indy Cars
Standard finishes: Gloss black, Matte black, Textured black, Silver, Gunmetal, Textured Gunmetal, Matte Gunmetal, Frost white, Race gold
Custom made: 8 weeks lead time for production
TPMS compatible
o All Forgestar wheels are provided with metal hub centric rings in order to mount the wheels.
18" Forgestar F14 have passed at a 1520 LBS or 690KG load rating and have JWL and VIA certification!
F14 Weights (will vary slightly depending on offset and wheel selection):
18x8.5: 17.6 lbs
18x10: 18.2 lbs
19x8.5: 22.5 lbs
19x10: 24.7 lbs
Pricing:
PM for pricing.
MSRP (per wheel)
F14
18: $440
19: $505
20: $640
22: $790
CF5
18: $440
19: $505
20: $640
CF10:
19: coming soon! Q1 2012
20: $640
F10:
20: $615
For more wheel info:
http://www.campionishop.com/products...nd=5004&clev=0
FLOW-FORMING
Forgestar's flowforming process is a unique solution to a common problem – how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
Cancellation policy:
Custom wheel orders cannot be canceled once the wheels are in production.
The making of a Forgestar wheel:
http://www.youtube.com/watch?v=uGYedhVpYgU
Pictures
R8 Spyder
CF5
Brushed Charcoal [NEW FINISH]
19×8.5 Front
19×11 Rear
B7 S4
F14
19×9 Front
19×9 Rear
Textured black
S6 V10
F14
20×9 Front
20×9 Rear
Piano black
B8 A4
F14 Brushed Titanium
19×10 Front and Rear 255/35/19 Toyo Proxes
S5 Cab
20×8.5 fronts Nitto Invo 255/30-20
20×10.5 rears Nitto Invo 305/25-20
F10
Piano Black with a Hyper Polish Step Lip.
S5
20×9.5 F
20×9.5 R
