New CQ owner, a few questions
Old Dec 28, 2011 | 11:19 AM
TomTucker's Avatar
Default New CQ owner, a few questions
Hi All,
Just picked up a 1990 Coupe Quattro. It is a little rough around the edges, but pretty fun to drive. I have a few questions as there are a number of lights/warnings on the dash...
1. Coolant light. The previous owner I got it from said it was just a sensor. Is this the likely culprit? If so, where is the sensor located?
2. "Brake" light shows up on the dash. Does the car have a low brake sensor on the calipers? Does it go bad frequently?
3. Sometimes when coming to a stop, the oil indicator light flashes on the dash. It goes away after I get going again. Checked the oil level and it looks fine. Any reason to be concerned?
I plan on stripping the interior, so if anyone has any bits in mind that they know they want, shoot me a PM. I'll post up in the classifieds section eventually.
Old Dec 28, 2011 | 03:13 PM
CRAZY_RUSSIAN's Avatar
first of all, do the required maintenance first, T-belt with coolant flush, i would use G12 coolant, you can get it from any VW/Audi parts store and or a dealer, change your oil, flush the brakes first, IIRC the fronts have a wear sensor thats integrated in to the pad ;-)
Old Dec 28, 2011 | 05:36 PM
varia's Avatar
read, read, read: http://www.20v.org
Old Dec 29, 2011 | 07:44 PM
squidix9's Avatar
No Bozos!
1. Yes there is a sensor integrated inmto the overflow container. Obviously check the fluid level, first. Then look at the connector on the bottom, they tend to corrode, then the sensor itself.
2. No the brakes (pads) do not have wear sensors. The light will come on for a pressure issue. Check the fluid and flush first. check the connector on the sensor as it like all the others does get corroded and give false readings.
3. Change the oil as necessary. If horribly bad flush and fill again soon. If the oil pressure is suspect then a manual pressure gauge is a must.
Old Dec 30, 2011 | 05:10 PM
varia's Avatar
"2. No the brakes (pads) do not have wear sensors. The light will come on for a pressure issue. Check the fluid and flush first. check the connector on the sensor as it like all the others does get corroded and give false readings."
plus the lovely brake bomb
Old Dec 31, 2011 | 01:09 PM
TomTucker's Avatar
Thanks for the replies.
Looks like the gasket around the water pump is leaking a little coolant. I'll tackle that when I do the timing belt. OIl change is first on the list.
Old Jan 2, 2012 | 04:56 AM
TomTucker's Avatar
Oil pressure is at 3-4 bar most of the time. It is only when the engine speeds get down to 1,000 rpm that it drops down to less than 1 bar and the warning notification comes on. Still something to be concerned about?
Also, how can I tell if the rear diff is going out? When I go around a right-hand turn (an on-ramp) there is a bit of a grinding noise. Can't tell if it is something rubbing, or if the diff will need a rebuild.
And last question before I get to work on all of this: What parts does this car share with other Audis of the vintage like the 80/90 etc? Is the drivetrain the same? Suspension?
Thanks again. I'll post pics as the transformation to track car gets underway.
Jack88
9
Dec 23, 2015 10:21 AM
CPLYONS
Sep 7, 2015 07:19 PM
zjw8407
Sep 2, 2015 05:20 PM
ArabianKnight
Miscellaneous - Archive
Sep 1, 2015 08:20 PM
stormchaser1967
New Member Welcome Area
Sep 1, 2015 01:29 PM
