picking up an 2000 tt this weekend??HELP??
http://www.cars.com/go/search/detail...nal&listType=1
Vacuum --- boost leaks are next to check for. Various hoses under the intake manifold tear and cause issues.
Check the cv joint boots also at that mileage.
Strut bushings and bearings at the top of the macpherson struts.
make sure the clutch feels "right" the slave cyl is inside the bellhousing , part of the throwout bearing.
Check the instrument cluster --- center display--- fuel-- temp gauges.
That's a start on the chronic stuff.
