The Power of Love!!! Our Valentines gift...Brought to you by Eurocode!!!
To usher 2012, the team at EuroCode Tuning is offer expert complimentary installation for the first 10 customers in 2012 that purchase APR's 2.0 TSI S3/Golf R K04 Conversion System from us. Priced at $2649.00 for transverse applications and $2999.00 for longitudinal, no system provides more bang for your buck than APR's K04!!
Our expert complimentary installation includes the following:
- Remove factory turbo and install APR's 2.0 TSI S3/Golf R K04 Conversion System $800.00 value
- Remove ECM and flash with APR's patented EMCS engine management calibration $150.00 value
- Flush coolant system and fill with OEM G12 coolant $50.00 value
- Five litres of Motul 8100 X-cess 502 00/505 00 fully synthetic oil with new OEM oil filter $90.00 value
- Total savings of $1090.00
Components
APR provides all hardware and software needed to ensure a complete install. All items which can be preassembled on the turbocharger come preassembled by APR. The APR K04 turbocharger system consisting of the following:
- APR EMCS Software
- APR Modified OEM K04 Turbocharger with Billet Compressor Wheel, Stainless Steel Exhaust Manifold, N75 Solenoid and Wastegate Actuator
- APR CNC Turbo Outlet Flange
- APR Turbo to Turbo Outlet Flange O-Ring
- APR Turbo to Turbo Outlet Screws (3x)
- APR Turbo Outlet Silicon Hoses
- APR Turbo Outlet Hose Clamps (2x)
- APR CNC Compressor Cover DV Mounting Flange
- APR Turbo to DV Mounting Flange O-Rings (2x)
- APR Turbo to DV Mounting Flange Screws (3x)
- OEM DV Mounting Screws (3x)
- OEM DV Mounting Screw Lock Washers (3x)
- APR Laser Cut PCV Port Cover
- APR PCV Port Cover Gasket
- OEM PCV Port Cover Screws (2x)
- OEM PCV Port Cover Screw Lock Washers (2x)
- OEM Turbo Manifold Gasket
- OEM Turbo Manifold Nuts (4x)
- OEM Downpipe Studs (4x)
- OEM Downpipe Nuts (4x)
- OEM Downpipe Gasket
- OEM EVAP Line One Time Use Hose Clamps (3x)
- OEM Oil Return Line Gasket (2x)
- OEM Oil Feed Line Washers (2x)
- OEM Coolant Feed Line Washers (2x)
- OEM Coolant Return Line Washers (2x)
Stealthy OEM Appearance
APR's S3 K04 Turbocharger Conversion System is constructed from OEM parts and appears OEM. It's easy to install and 100% reversible. Every OEM part is fully Plug and Play:
- Exhaust (Upgrade Highly Recommended)
- Intercooler (Upgrade Highly Recommended)
- Intake (Upgrade Highly Recommended)
- Diverter Valve
- Positive Crankcase Ventilation Lines
- EVAP Lines
- Coolant Lines
- Oil Lines
- Turbo Support Brace
Dyno Performance
Local installation we performed
To schedule and appointment or if you have any questions, please feel free to call us at 310-294-8108 or email info@ecodetuning.com
