Power seat problems
Pic was when I first got it, I have since replaced the brakes, gas line, and new tires
You can tilt the seat up in the rear and access the motor to move it forward and backwards. There are 2 screws connecting the motor to the seat frame. Take these out and flip the motor around and set the square connections back in place. Check if the seat will move in the other direction.
If you seat only moves in one direction, it is probably in the switch. This is a PITA fix. If you are the only one driving the vehicle, you can move the seat into "your" position and then disconnect the power connection so you or someone else does not move the seat.
