20" Tire Pressure
Old Jan 30, 2012 | 03:53 PM
Texas Audi's Avatar
Default 20" Tire Pressure
Upon delivery, the dealer has the tire pressure at 35 psi and the door and manual indicate 46-48 psi. I am inclined to inflate to the instruction, but did not know if any of you all had this issue and what you did.
Old Jan 30, 2012 | 05:09 PM
manishaudi's Avatar
You should. 35psi is too low. My dealer does a full check whenever I take my car in, including tire pressure.
They set my tires to the following pressure:
Front: 44psi
Rear: 46psi
Old Jan 30, 2012 | 05:18 PM
uberwgn's Avatar
Super Moderator
Tex, check your Owner's Manual. It's the only place you'll find comprehensive inflation information on cars sent to the USA. The door pillar label displays MAX LOAD only (5 adults, 5 suitcases).
Old Jan 31, 2012 | 04:35 AM
The G Man's Avatar
With low profile tires, you want to set the tire pressure higher to protect the rims. I would set it to low 40s.
Old Jan 31, 2012 | 06:53 AM
Texas Audi's Avatar
Thanks guys I appreciate it. We are going to Houston so I am taking the car in today for a check up and get the tires taken care of.
Old Jan 31, 2012 | 09:04 AM
jr'sAudiA6's Avatar
The door pillar tire pressure info is the max load settings. After reading the manual I settled on a pressure of 41 front and 39 rear.
Old Feb 1, 2012 | 06:50 PM
spoon2000's Avatar
I would split the difference between pressure specified in the owner's manual for the the regular and maximum loads and go with that. That should give a good compromise between ride quality, gas mileage, tire wear, and rim protection.
The way I like to adjust tire inflation pressure is to over-inflate the tires by a few PSI at the gas station, then take the car home and park it overnight. The next morning before setting off, I bleed down the tires to the correct cold pressure. At that point, the the pressure monitoring system can be reset as well and so it's locked in on the correct PSI.
Old Sep 19, 2015 | 10:07 AM
mchltschr's Avatar
Never even paid attention to "max" load against normal load. Ignorance on my part. Just dropped the pressure on my 255/35-20's to 41 Front / 39 Rear. This is a tad higher than the manual recommends for normal load, but will feel it out and see if adjustment is needed.
Dealer had mine set at 35 all around which is low.
Thanks gents!
 Michael S. Palmer
Old Sep 19, 2015 | 10:24 AM
qqq1970's Avatar
For same reason I set to max.
Old Sep 19, 2015 | 04:31 PM
Hulamau's Avatar
Front: 44psi
Rear: 46psi
Disagree, unless you have 5 people in the car with full luggage load setting to 46 -48 ire pressure on 20" tires will turn them
Into bricks
Read the manual for a drive and one fronts seat passenger go with 38 - 39
As a good alternative or 39-40 tops when and those are only COLD tire morning pressures before driving at all and not after you have warmed up
The engine which heats up the front tires a good deal too.
