Audi A6 C7 Trunk closing.
Have a A6 (C7) bought new in November 2011. I find that I cannot close the Trunk (boot in the UK) on the first attempt. I need to close it shut with a little force, otherwise the trunk does not take the latch. Anyone experience this problem. Fault or a design flaw ? Grateful for any thoughts.
(2.0tdi S line Multitronic,Saloon. Ibis).
https://www.audiworld.com/forums/sho....php?t=2821511
I reference a part available in the US. There may be an equivalent in the UK.
Mention it next time you go in for service, they might be able to adjust the latch.
I guess you could screw around with the settings/options until you track down what it is, not worth it to me.
Trunk rubber seal
Driver side door rattle (most likely LED strip)
MMI screen occasionally not deploying
On our new A6, the door insulation on the front edge lip of the left rear door was loose and had gotten bent into an odd shape; you might check yours to see if that's causing problems.
