95' 90 Quattro Rear view mirror came off?
Anyways, I have used the special epoxy from the auto stores and when I worked at a dealer years ago.
My question is, most have a set screw so you can remove the metal Pad from the mirror so all you need to do is put a drop of the epoxy and hold it there for about a minute.
That's a lot of weight if you have to hold that big mirror in place for it to set up. I don't see where that round metal pad comes off the mirror either even though it looks like Ther is 2 notches on the one side.
Anyone ever glued one back on that maybe knows something that Im overlooking?
Thanks, Duane
In the meantime I will try another search on it
I snagged the electrically auto dimming rear view mirror from a old caddy and put it in there. Just run a 12v to it and you are good to go. it works awesome. These same mirrors come in a dozen or so GM models. I even think I have a few extra around here.
As for the adhesive, just get the stuff form your FLAPS and follow the directions. Be sure to clean the area with isoprophonal and a razor first.
Thanks, at first I didn't know if that base came off the mirror..
Duane
I can't believe Audi, (Well yes I can), but changed the Mirror styles even between those years on the same Model even.
Thanks for posting the Photos, so Other members know also that things are not always the same.
