FPR and Vacuum line question
Old Feb 10, 2012 | 10:14 AM
BR TT's Avatar
Default FPR and Vacuum line question
I have an 01 225 TT AMU motor. Last year my Timing belt went and the local Audi shop did the repair, since then I've been having problems with going lean. I did a boost test and found a few small leaks but while I was checking the lines I noticed the Vacuum line going to the fuel pressure regulator looked like it is pinched at a bracket that supports the intake manifold. is there a T connector or fitting down there I don't know about? I thought the Vacuum line from the FPR goes directly to the nipple on the passenger side of the intake manifold only.
If someone has a vacuum diagram for a 225 Amu motor I would appreciate it. I've searched all over and can only find the 180hp diagrams.
adubs777
Dec 19, 2008 04:31 AM
couper83
Jul 30, 2008 07:28 AM
TCU_TT
16
May 6, 2008 04:37 AM
poopeter-el sigthief
Jan 5, 2003 05:35 PM
sTTanford
Jul 2, 2002 10:45 AM
