1999 A6 2.8 Exhaust replacement question
The center resonator needs replacement, so I am ordering Bosal Part Number: 7440-05100838 from Partsgeek.com
partsgeek.com lists 50mm clamps forward and 42mm clamps after, however I have been to Shop A and Shop B and they both just simply quoted 2 inch clamps.
Shop A quoted over $2400 for the repair, they are not even living on the same rock as the rest of us. Note they insisted on replacing everything from flex pipe aft.
Shop B quoted $962. $70 of labor, they told me (and I agree) that the rear LH and RH mufflers are in great shape, and just the center res needs replacement. $676 for that part, and $38 a piece for clamps (4). They are willing to use customer provided parts, but their labor with be $125-$150 instead.
So to order the correct clamps, I was wondering if anyone knows for a certainty what the factory pipe sizes are. 2 inch? or 50mm and 42mm.
For reference I was thinking about:
7440-05100838 Muffler (1x) $216
W0133-1634113 50mm clamp (2x) @ $12.85 each
W0133-1919708 42mm clamp (2x) @ $14.85 each
from partsgeek.com
if they are just 2 inch, can I get away with the 2 inch band clamp 7440-05119134 ? $2.85 each or must I use the dual clip type as listed above?
Thanks, this stands to save me a bit of cash and help keep our A6 on the road.
P.S. Yes I know 50mm is about 2 inch.
If so, do you care? Why not put an aftermarket, non-OEM replacement, since your car isn't new? Shouldn't be $620 for the part itself.
When you say used i take it you mean go torch one off an A6 in a junkyard? Since the factory original is stainless steel, this is an intriguing idea. But you never know how bad of shape it will be in and how long it will last. The Bosal one i'm looking at new should at least last 4 or 5 years.
Why not take your car to an independant shop and have them bend a couple of pipes to replace the resonator? It would probably cost a hundred bucks or so out the door. It is a 13 year old car and there is no reason to spend more than the car is worth on a resonator.
Have a nice day
Steve
Have a nice day
Steve
At prices of less than $300 for aftermarket resonator, shouldn't be a problem. At $600+, I would go to a different shop.
I have found a shop that will install customer brought-in parts, so I don't want to pay $645 for a resonator and $38 per clamp (4 clamps!) when I have found the same parts for much less.
The more I think about it, if I'm going to creep under the car, I might as well cut out the exhaust with a torch and just clamp the new one in myself and save the $150 in labor. Anyone done DIY exhaust before?
Thoughts?
