2003 A6 dont want to start sometime, instrument cluster failur?
I have run vag-com and had the following errors in the cluster (no other fault codes at all)
Is the problem the instrument cluster?
If it is, I have a cluster whitout the trip computer(?) whit only two connectors on the backside, I have found a lots of used cluster that have the big lcd and three connectos at the backside, can I code onw of these to my car?
Address 17
Controller: 4B0 920 901
Component: KOMBI+WEGFAHRS. M73 D06
Coding: 00144
Shop #: WSC 00000
1 Fault Found:
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
After I cleaned the code it came back, and after I cleaned it again and try to start the car I got the following
1 Fault Found:
I can look tomorrow if it's wet under the seat.
The last maintenance was a oil service a year ago, and after that I got a new ECU installed on warranty from the Audi dealer that sold the car, this was 10 months ago.
Now what? replace the central locking module? does a new one need be coded?
The fault codes in cluster also coming back.
loose contact on the cable / connection to the starter so I worked some times and sometimes not.
