2 fault codes, where are sensors? G71 and G31.
Old Feb 15, 2012 | 03:54 AM
Jack27t's Avatar
Default 2 fault codes, where are sensors? G71 and G31.
Hi all,
My saga continues. Got car back after finding the waste jammed open by a lost nut from last fix. Now the car is tossing 2 fault codes.
1. Manifold / Barometric Pressure sensor G71/F96
2. Manifold Pressure / Boost sensor G31.
I believe that G31 is on top of the rubber boot between the pipes and the throttle body.
Where is the G71 sensor?
Thanks for any help.
Old Feb 28, 2012 | 06:19 AM
Jack27t's Avatar
OK, both code point to the boost pressure sensor in boot at the throttle body.I replaced the sensor and things are back to normal again. Oh, I picked up a used sensor and it works fine. I saved 200.00 over retail.
2XTurbos
10
Nov 15, 2009 07:11 PM
Joao
Aug 19, 2008 04:12 PM
Seabeast11
Mar 10, 2007 05:06 PM
back2black
26
Jul 10, 2004 10:14 AM
