easiest way to raise car for service
Search and you will find instructions for a great method using a length of plastic tubing, an old metal coat hanger, the bottle of new fluid, and an air compressor. I recommend not much more than 15-25 psi, any more and the new bottle of transmission fluid starts to bloat scarily like it might burst!
Make sure you can loosen the fill port before you loosen the drain port & drain the transmission!
Also, VAG COM is your friend, you are looking for a spec temp for the transmission fluid.
A great tool for filling /topping up is a Motive Power bleeder. It holds ~3 liters at a time. I fabricated a "J-Hook" tip using copper tubing. It Worked great. And Didn't spill a drop.
It's also obviously indispensable when flushing your brake fluid...
Furthermore, it seems to me that it would be a good thing to have the transmission cycled through all its gears, i.e., for all the various valves and hydraulic actuators to be actuated during the fluid fill, something that simply cannot be accomplished with the wheels stationary. On a ramp(s) the only gears cycled are first and reverse; however, ZF procedures and Audi say handbrake on, etc.
One ZF source for 5HP24 trans says the handbrake is ON, therefore the wheels don't have to turn:
http://akpp-city.ru/pdf/5HP24A.pdf
That being said, one ZF procedure for BMW transmissions indicates the wheels don't have to move:
1. The transmission temperature must be between 30°C and 50°C before checking can begin. Use the DIS or the MODIC to determine the transmission temperature. <Audi would be Vag-Com>
2. The vehicle must be level and without load. With the engine running, switch on the air conditioning. This will increase the idle speed and ensure that all oil passages in the transmission are filled with oil.
3. Step on the brake firmly, apply parking brake fully and move the selector lever through each gear position, pausing briefly in each gear.
4. With the engine running and the selector lever in Park position, remove the filler plug located on the transmission (see picture for location). If a small stream of oil runs out, the fluid level is correct.
5. If no oil runs out when the filler plug is removed, the fluid level is too low. Add oil until it starts to overflow.
6. With the engine running, reinstall the oil filler plug and tighten to proper torque. (Refer to section F below for proper tightening torque)
Also, I was not aware I am to allow the wheels to move when moving through the gears as I refill the trans. The last time I did it on jack stands I remember being told to move through the gears pausing for 10-30 seconds but with the brake on. This seemed to work fine. Was I wrong? Should I have allowed the wheels to rotate?
