19" sport wheels weigh 58lb each
Old Feb 16, 2012 | 08:13 PM
DGS4's Avatar
Default 19" sport wheels weigh 58lb each
In case anyone was wondering. That's with OEM tire installed and inflated to ~38 pounds of air. It is the prestige wheel 15 spoke star. Part number is in a previous post, pic is in my folder. And yes they are sold, thanks for all the interest.
Old Feb 18, 2012 | 04:07 AM
snagitseven's Avatar
Super Moderator
I wonder how much they would weigh if there was no air in them. :-)
Old Feb 18, 2012 | 06:27 AM
arefog's Avatar
Well that's easy.....take out the 38 lbs of air and you're left with 20 pounds.
Old Feb 18, 2012 | 07:03 AM
MonzaA5's Avatar
I hope you're being sarcastic
Old Feb 18, 2012 | 09:07 AM
at1183's Avatar
doesn't quite work like that... 58lbs for a 19" wheel with tire and air, would lead me to believe the 19" wheel is around 27 - 29lbs alone...
if the OEM 19" wheel was only 20lbs... everybody would be picking up a set
Old Feb 18, 2012 | 10:13 AM
mwar99's Avatar
38 PSI - not 38 pounds, in weight, of air.
Old Feb 18, 2012 | 10:36 AM
BugeyeRX's Avatar
Bahahahahahahahahah..... whewwwww!
Old Feb 20, 2012 | 05:30 AM
arefog's Avatar
Jeez I hope nobody thought I was serious............
This is really pretty simple - Tire Rack says the OEM tire weighs 27 pounds, so the OEM 19" wheel weighs 31 lbs. Sounds about right for a cast (probably) "overbuilt" 19" factory wheel.
Of course, we don't know if the 38psi was measured with the valve stem at the top or the bottom of the wheel. Makes a difference, ya know?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 20, 2012 | 07:04 AM
Super Moderator
And don't forget to factor in the weight difference of the front vs. rear wheels.
Old Feb 20, 2012 | 05:15 PM
tenspeed's Avatar
I filled a tire with helium and I had to put weight in the trunk to keep it on the ground.
