How low can you go for 1999-2002 TT Mileage
Chuck
10-15 miles a week, not sure that's a good thing. Cars need to be driven.
If it's a weekend toy, replace the brake fluid of course as it will be pretty much useless by now. I would change the engine oil and filter once a year, synthetic oil good quality filter. Drain and fill the Haldex. The Hungarian rubber parts tend to shrivel up on these cars, check the shock upper mounts and the suspension in general, also the engine + transmission mounts .
The big thing is the timing belt, can't advise you there. Maybe have it checked. The belt will be dried up and the tensioner is probably questionable.Water pump might be OK although it probably has a plastic impeller which in the early days wasn't very durable. Drain and fill the cooling system maybe.
