Help, I'm stumped. Heat On/Off Car overheating
UPDATE: It was the water pump, impeller completely off the shaft. I guess sometimes it got caught by the shaft but as soon as I drove it would slip off and on randomly, until it didn't catch at all anymore (well I didn't want to test it that much because what if the impeller became crooked and caused the shaft to lock up, engine BOOOM)
is this a water pump/thermostat issue now? how come there is no heat inside??? shouldn't there be heat even if the thermostat is stuck?
The thermostat only bypasses part of the flow when the engine is cold, so there is always some circulation through the heater core and the radiator when the engine is running.
You could also check to see if the coolant in the expansion tank (reservoir) and/or the radiator is hot when the engine temp shows normal (check before it overheats...) If not, there's no circulation from the water pump.
The combo of it overheating and the lack of circulation through the heater core kinda says that in running it dry you may have killed the water pump. Only kinda good news there would be if the mileage is close to needing the timing belt done too...
Jim
i've been sitting in the car for like 30 minutes. heat goes on and off. mostly once at idle and the heat is on it will stay on for like 5 minutes and then shut off. then it will start overheating and i'd shut the engine off, then I'd put it back on, heat is back on until it stops again and starts overheating again. if the heat is on and i begin to drive around the block it goes off right away and starts overheating...
Jim
i really really wanted to get the kit from ecstuning but the instructions blauparts includes and the tool kit made me decide to order from blauparts.... i know ecs would have higher quality parts, but at least on this timing belt job I want as many instructions as i can get, (my first timing belt job on any car) AND THEN I'LL FINALLY GET A CHIP!!! YAY
Jim
