Weird issue with my 225
Old Feb 24, 2012 | 09:46 AM
markcorrado1's Avatar
Default Weird issue with my 225
I'm having a super weird problem with my 225 TT and I'll try to describe the issue to the best of my ability...
I have an APR chip, EVOMS intake and a Jetex Exhaust for mods. Dog bone mount is new (ECS Ultimate), tranny mount was installed about 10k miles ago (street density 034) and the mount on the TB side was changed when I did the TB job at 60k (street density 034) and I'm currently at 116k miles now.
When I press into the gas 1/2 way or more down, I get this really weird thudding sound that has like a rotating or vibrating kind of noise. This mostly happens in the first 3 to 4 gears as torque builds up the quickest in those gears. But if I gradually build up speed by pressing on the gas a 1/4 way down, the car picks up speed and no thudding/vibrating noise. If I rev the car out of gear I get no thudding/vibrating noise either.
I spoke to an Audi tech and he said it sounds like maybe clutch, throw out bearing or pressure plate is going bad... But I thought to myself, usually if a clutch is going bad you just get bad RPM drops or if the pressure plate was bad the shifter would be hard to get out of gear... The only other thing I could think of is maybe the drive shaft is going bad.
Does the TT have a center bearing for the drive shaft? I remember when my boys SC with a 1J had a bad center bearing for the drive shaft. The car would thud when pulling off or when you geared down...
Has anyone else experienced this type of behavior with their 225 TT???
I'm at a loss as to what this problem might be
Old Feb 24, 2012 | 07:46 PM
AudiMick's Avatar
Original clutch, might be one of the outer springs on the dual mass flywheel broken. Noise could be related to more torque on the drivetrain. At light loads it's OK.
Old Feb 24, 2012 | 08:12 PM
Yep at light loads its perfectly fine... After doing some searchs on TT-Forum UK, I'm really wondering if it is the propshaft (drive shaft) And for the life of me I can't understand why Audi has made it so hard to replace all the parts on the shaft :O
http://www.wak-tt.com/guides/propshaft.pdf
Old Feb 27, 2012 | 06:31 PM
Figuered out what the problem is, it's mosdef the prop shaft coupler ;( It's hitting the sway bar and a bit of the down pipe heat sheild
macdady
Jun 14, 2007 06:02 PM
1-pippin
Nov 9, 2006 07:30 AM
EDIGREG
Audi 100 / A6 (C4 Platform)
Oct 18, 2005 10:55 PM
BoostFrenzy
May 8, 2003 05:34 AM
T13Ray
Sep 3, 2002 03:58 AM
