URGENT: Doing timing belt job cam MOVED
Put away the white out. It will only confuse you when installing the new belt and setting the cam timing.
i did use white out on the old belt and counted 89 teeth between the marks, i made sure there were 89 teeth between the marks on the new belt, but I didn't make a mark on the crankshaft sprocket but i doubt that it could be different if the marks on the cam sprockets are the same. tension was even all around.
Also, the counting teeth exercise is laughable...that's what the TDC pin for the crank and the timing bar are for, to lock in the correct timing. Whatever the timing was on the old belt, the new belt will change it, probably not significantly but it won't be to audi specs.
The reason I changed the belt was because my water pump went bad, the impeller was completely off the shaft. I did change the rollers, but then I realized I had the lever too and didnt feel like changing it, I had a feeling that it was torqued more precisely than I could with my torque wrench that starts at 20lbs/ft...
In all I changed the timing belt, serpentine belt, water pump (both plastic impellers,old and new) thermostat, timing idler roller, tensioner roller, tensioner... My car used to leak a lot of oil (1 quart every 3-4 weeks), but after I changed the transmission and changed the cam plugs on the back of the engine the oil level has not changed for the last 3 months.
And like I said, if my car starts and runs fine tonight, I will be more than happy to change the seals that I didn't change when they do finally leak.
Question:
When I had the cam lock bar on and I unscrewed the cam bolts and popped the sprockets off, do the 2 ears that the cam lock bar go on move around the cam shafts? or they are fixed even if you take the sprockets off? they only go in 1 way or something?
First of all, given this question, it does sound like you set it correctly. Kudos.
To answer the question, the sprockets spin freely, the little plates with the ears are keyed to the shafts. So basically you use the bar to engage the little plates to lock the cams in the correct position and the pin locks the crank position. When you tighten the sprockets back down, they are in the correct position. Make sense?
