Crankshaft Locking Pin only goes in half-way & wont lockdown the crank.
So I pulled out the plastic plug from the block along with it's O-ring and the proceeded to hand-thread this Pin tool. I easily got 13 turns done by hand but then I was only able to get about a half-turn with a wrench. The problem is that this is not enough turns to lock-down the crank shaft. There's easily another 6 turns of thread left on the tool but I can not wrench it anymore without slipping off/stripping the tool with the wrench.
Here are the pics - what do you think?
http://s235.photobucket.com/albums/ee271/njcotte/
1. Yes, I did try turning the crank back and forth a few degrees (with the camshaft sprocket lock bar installed) & with the Pin half-way installed in the picture. And with the pin installed as pictured I could have kept on turning the crank in either direction for as much as I wanted to. The blaupart instructions say "With a 12 point 24mm socket wrench, double check that the crankshaft will not move by lightly turning the crankshaft".
2. How do I know it's lined up meaning how do I know the crank is at TDC and the camshafts are likewise at TDC? I just turned the crank to lineup the TDC mark and since the camshaft came up as being at TDC I'm assuming therefore that everything is lined up correctly at TDC.
After what you just said I'm starting to think that the crankshaft is designed with a certain divot when it's truly at TDC to accept the locking pin tool - or am I reading too much into this?
Remove the cam locking bar until you get the pin locked in. I've seen them off by as much as 10 degrees. I've also seen the divot get packed with sludge, so you might try sticking a sharp screwdriver in the hole to clean out the divot.
This car ran fine, just not as quick as other 2.8's. A timing belt service transformed the car. Note that the cam locking bar is installed (you can see it in the foreground) and that the arrows show timing to be at least 10 degrees off. This is also evidence that the tools must be used for the proper result.
http://www.blauparts.com/audi_techni...t_pulley.shtml
The engine will time correctly if the crankshaft sprocket tang is tango uniform as long as the crankshaft/sprocket is tight...the harmonic balancer timing mark will simply be øff.
