ok, timing belt job done, but now water leaking
sloop said something about a bleeder hole on the thermostat, hopefully mine isnt in the 6 o clock position, because I didn't even realize it mattered?
The leak was like on a faucet at a very low setting when its just a 1 drop complete line, but then you lower it and its a broken line. then it became 1 drop every 1/2 second or so after I had the engine running for like 30 minutes. the coolant level barely changed so far...
let me know if I need to tear the sucker apart and check that thermostat position. i'm really happy the timing belt job was almost a complete success, i'd be 100% if there was no leak.
For t-stat, it sounds like you have the stat seated against the block (hopefully with the little valve at 6 O'clock), then the o-ring, then the housing. If so, that is correct.
If the housing is not set back onto the block correctly, it can **** to the side and pinch the o-ring.
This morning I ran the engine till it was at normal operating temps, and then put the ac on (my ac fan doesn't want to work anymore, this summer it was humming like a generator) and held the rpms at around 3K and I finally tested full WOT and nothing broke, then the leak stopped. While the engine was warming up it was 1 drop per second... Now its completely stopped. Perhaps the o ring heated up and finally sealed everything? or maybe when I had the car in service position I pulled the lower coolant hose out of the block a little (but I doubt that, it does look a little wet, but I cant tell if its oil or what)...
actually neither of the electric fans turned on at all today, engine oil was a tiny bit above 200degrees and coolant was at center and I was revving it from 3K for a minute and then boosts to WOT, and none of the fans turned on with the ac on lo/lo...
ohh and when i was warming up the car (so the coolant would be at center) I was holding the rpms at 2k but something kept turning on and rpms would lower about 150-200rpms and then when it turned off it would go up 150-200rpms, what does that? it does it almost all the time, i noticed that before too when the water pump was going bad, but sometimes it didn't do that at all...
It is possible--just barely--to check below the housing without disassembly. Spot flashlight and a mirror; check the "pocket area" just below the t-stat end of the housing for a small dribble. You're more likely to see it as the car's cooling down.
