How to figure out which rims are bad?
Old Mar 2, 2012 | 04:26 PM
badinstincts's Avatar
Default How to figure out which rims are bad?
I have a vibration problem. I've been changing the tires with used tires for a while and cant get rid of the vibrations. Perhaps my rims are bad? they are the stock turbo style wheels on the 2001 Audi A6 2.7T Quattro
Please let me know how I can check or which type of balancing equipment I should look for at a tire shop for them to tell me if my wheels are good, I'm really tires of the vibrations in my lovely car.
Old Mar 2, 2012 | 05:02 PM
5v/cyl's Avatar
If the vibration is felt in the steering wheel then it is in the front. If you feel it in your butt then it is in the rear. Rotate the tires front to back and see if the vibration follows. If remains unchanged then you are probably looking at a driveline vibration which would be CV, center shaft, or wheel bearings.
Old Mar 2, 2012 | 05:09 PM
jcman's Avatar
Most all newer tire balancers can spot a bent rim at a tire shop, I have two on my 04 flat five's "not fat five" that were brought to my attention during the winter set change and balance in November, found two new ones that were spares for a steal.
Old Mar 4, 2012 | 05:56 AM
Just Me's Avatar
Tech Guru
Tech Guru
Just watch the edge - typically the inside edge - while it spins. Your eye is more than sufficient. For unexplainable reasons, most technician's eyes are not sufficient.
If you have 10 year old factory 17s, i *guarantee* there is a slight dent to an inside edge on at least one wheel. Over my life, on several audis, i've bent, and repaired, more than a dozen.
G
Old Mar 4, 2012 | 01:25 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
I put the car up on jack stands and in gear, engine idling. I watch the tread/tire...if it wobbles either the tire is bad or the rim is bent. Getting a good view of inside rim isn't too difficult either. But if the tire wobbles generally the wheel/tire has to be broken down. If rim isn't bent, get the wheel/tire assembly rebalanced with a road force balancer that might entail rotating the tire on the rim 90 degrees and then rebalancing for minimum road force.
So far I haven't been fooled by flatspots on the tires....but if there were flatspots from hard braking with failed ABS for instance this might not work so hot.
Old Mar 4, 2012 | 01:35 PM
so how do I do this with quattro? I have to have all 4 wheels up or can I lift the front and use the emergency brake to hold the rear?
Old Mar 4, 2012 | 02:54 PM
Tech Guru
Tech Guru
As it happens, quattro is generally open diffs...just jack up the front, hold the rear with parking brake.
Don't goose it and don't run it for a long time, just idle in gear and watch the wheels turn.
But why not put it up on all four corners while you're at it and be done with it?
Old Mar 4, 2012 | 03:07 PM
Just Me's Avatar
Tech Guru
Tech Guru
this will work, but the (i hope) low speed on the lift makes it harder than on a balancing machine, IMO.
G
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 4, 2012 | 03:08 PM
Just Me's Avatar
Tech Guru
Tech Guru
4 jackstands.
Old Mar 4, 2012 | 06:39 PM
Tech Guru
Tech Guru
Balancing machine generally uses an index or steel pointer near the rim with or without tire mounted. Rotate by hand to get clear indication of where bent. spinning on car just tells u wheel or tire is out of round, quick check without asking wheel off car.
