can you replace just the bearing in the engine driven fan?
Old Mar 3, 2012 | 02:20 PM
rs4-380's Avatar
Default can you replace just the bearing in the engine driven fan?
On a 2.8?
Old Mar 4, 2012 | 06:41 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
U mean in the viscous clutch? Not as far as I can see.
Old Mar 4, 2012 | 07:03 PM
rs4-380's Avatar
well not the actual clutch but yes the bearing in the bracket/pulley that drives the viscous clutch/fan.
Old Mar 5, 2012 | 07:16 AM
Tech Guru
Tech Guru
Maybe. I don't know the particular bracket/pulley/bearing you have, but I once did something similar to an OG900T saab a/c tensioner pulley/bracket. Drilled out the rivets, replaced the pulley for $4-5. The bracket is about $75 today...
Old Jan 4, 2013 | 01:45 PM
rs4-380's Avatar
bumping this back up, as it really needs to be replaced at this point. I've called a couple parts places and they couldn't even locate a part, but everyone who sells the clutch says it comes without the bearing.
ANy ideas?
Old Jan 4, 2013 | 09:59 PM
OGBULLYLOCDAWG's Avatar
ANy ideas?
What wrong with the one on the car currently?
Try "fan clutch pulley", I don't know if that's the technical name for it or not.. but it will get you a few hits.
Old Jan 5, 2013 | 03:20 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Bumping sux.
Old Jan 5, 2013 | 11:38 AM
rs4-380's Avatar
it makes horrible dead bearing noises.
I've actually answered my own question to a degree, the bearing is usually sold as part of the bracket/mount. You can buy one new for 250$ but that is way more then I want spend to fix this problem. I'm trying to hunt down used parts.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 5, 2013 | 12:39 PM
Tech Guru
Tech Guru
get the actual p/n and google it.
Isn't the fan clutch mounted on the water pump shaft? Or is your fan turned by the serp belt?
Old Jan 5, 2013 | 03:15 PM
Get a used one.
This is the first time I've crossed a post about that specific pulley/bracket going bad like that, so it may be one of those parts you can just replace for cheap.
I sent you a link via PM
$45 + free shipping
You can't beat that.
EDIT: But please double check your part number with theirs, I'm not affiliated with the seller in anyway, so I don't want you purchasing the wrong thing on a recommendation made by me on here.
I don't know if there's a difference in part #'s between the ATQ/AHA 2.8 motors, but it looks like the one on MY2001 with the ATQ.
