Adding sub and amp to Bose system
My JL Audio CP108GL box has not arrived yet, but I decided to go ahead and install the amp anyway.
Good thing the battery is in the trunk, very easy to run the power line. The ground point is right in front of the Bose amp.
Looking at the Bose sub under the deck, you might think the wires should be Grey and Grey/Red, but no such wires in the Bose connector.
Looking under the speaker grill, it turns out the wires are actually Brown/Blue and Brown/White
Spliced into these at the Bose amp.
Continued in next post.
Fastened a couple of braces on the bottom of the amp, to get some air between the two amps.
Secured the JL Audio amp on top of the Bose with a strap.
Done! Now I just have to wait for the box to arrive and plug it in. Can't wait to hear what it sounds like!
Do you think soldering was the best choice? (in case the fuse ever blows, you need to resolder)
Have you ever heard/seen the "Add-a-circuit" fuse method. Link below
http://www.google.com/search?q=add+a...w=1280&bih=646
Can't wait to hear your feedback on the outcome. I havent even taken delivery yet, but so far, a lot of people seem to say the Bose is sub-par... I plan on doing something similar myself once i get the car
The Bose system sounds great except for the pathetic bass performance. I have very high hopes the extra sub will make it sound great overall!
