Odd Boost Issue
Old Mar 5, 2012 | 05:10 PM
TPW's Avatar
TPW
Default Odd Boost Issue
I have a 2001 180 TT Quattro. When I put my foot into it it seems to boost fine to about 16 psi, then the engine cuts out for a half second, so I let up on the throttle, shift gears, put my foot into it again and the same thing happens. It never goes into a limp mode and will work fine as long as I don't try to accelerate too fast. The only code I get is 17963 P1555 ( max pres. exceeded), but no CEL's. I replaced the N75 with another stock valve, and checked the hose from the N75 to the turbo for leaks. The wastegate seemed to operate fine when pressure was applied. Any other ideas?
83UR-Dont-run
Oct 19, 2010 05:08 PM
The Chad (VaultPSU)
16
Nov 13, 2007 07:33 AM
koolhand
Mar 12, 2007 05:09 AM
Hal_TT::CBP
12
Jan 16, 2006 04:23 PM
