SAI valve vacuum hoses, what to do with them?
So I want to install the block off plates, but there are these small hoses that go to the valves on both sides of the engine. What do I do with those small hoses?
also, I really think I have a clogged spider hose. the part where all the hoses come together in the middle has oil all over it.
so should I plug the 2 small vacuum hoses that used to go to the combi valves or what? They both join together in the middle of the back of the engine and then it goes under the intake manifold to lord knows where...
You can plug both hose's otherwise you will loose vacuum when the solenoid at the other end calls for the valves to open via diaphragm.
my car lasting longer vs less emissions, I choose car lasting longer! more than half of the aholes on the road pollute a lot more than my car.
Maybe the inspector won't look, maybe he will.
In MD they don't even pop the hood...just plug into the OBDII connector. Probably the same in NYC.
