idle issue?
Other places to look: Spark plugs and ignition coils, how are yours? If they are old/bad, you can upgrade to the MK5 coil packs, Integrated engineering sells adapters.
The MAF sometimes acts funny, if you unplug it and the car runs better, then you've got a bad MAF. What year is your car? What engine?
Yet more things:
-Try a throttle body reset
-Your CTS, is it a black or green top?
-Any faults with VAG COM?
-Is your alternator in good shape? How about the battery?
Do a search with uncle Google for "TTweaker’s Guide v0.6". Try to detect your car's general health. Once that is set, they need less and less maintenance.
Good luck.
They get soft spots in them from age and heat that you can't see and can collapse and pinch off momentarily under high vacuum at idle.
When you take them out you can see the soft spots in them which will kink easily by rolling them into a circle.
