Camshaft position sensor
Old Mar 20, 2012 | 03:50 PM
lozts's Avatar
Default Camshaft position sensor
Hi Folks!
My car has been shifting funny so I hooked up the VAGCOM and it came back with P0346 :: Camshaft position sensor bank 2 sensor A. Can someone tell me which one of the sensors this is? I've located all 4 so I just need to know which one this is, so I don't have to play guess and check.
I have a 2005 A6 3.2L Q.
Greatly appreciated.
Old Mar 20, 2012 | 04:37 PM
4Driver4's Avatar
Tech Guru
Tech Guru
You want the C6 forum.
Old Jun 17, 2012 | 09:30 AM
lozts's Avatar
Just thought I'd post solution to this issue:
It turns out it was the camshaft position solenoid valve NOT the sensor and it was an easy fix. It took me all of 10 minutes to do and cost me $98 because I bought it from the dealer just to later find it online for $68 shipped (link below). It's held in by 1 star screw. You should examine all four of the camshaft solenoid valves to see if any of them look noticibly damaged (mine was loose around the crimp) or have a mechanic look at them/scan your car to see if he can tell you which one to replace. Mine was in bank 2 on the drivers side on the back of the block. If you are getting the same code then it could be the same one.
Part Number: 06E 109 257 J
Can be purchased here:
http://www.ubtuning.com/?product=364
Good luck!
Old Jun 17, 2012 | 09:34 AM
lozts's Avatar
FYI: The issue with the solenoid valve was causing the sensor to only get 5V instead of 12V which was causing it to throw the code for the sensor.
Will Merritt
Q5/SQ5 MKI (8R) Discussion
Sep 13, 2022 04:08 PM
Eric Falkiewicz
Mar 25, 2018 08:32 PM
carterleeds
Jan 5, 2013 01:49 AM
Sal R.
Jun 29, 2006 07:49 AM
98Blue
Jul 23, 2003 07:39 PM
