Picky/Hesitant Acceleration + Left-Turn Squeak
Thoughts? CV Joint? Wheel Bearing?
The other issue is the acceleration is quite the picky little thing. Sometimes I am slammed into my seat by the torque on a green light and then other times I feel like i'm driving a grandpa cruiser. Its either hesitant, choppy and weak or its better than my pop's Beemer. The car also shakes about 20% of the time its going between 70mph and 80mph. I'd love some consistency with her. Any thoughts on this?
Any replies are greatly appreciated.
The acceleration is indeed the monster that is the automatic trans coupled with a pretty slow engine. The 2.8 doesn't have a lot of power below 4k rpm and so unless you keep it up there (either with your foot on the floor or the tiptronic) it has a hard time moving very much. You get used to it and it's a fairly predictable machine; you can flick your toe to get it to down shift when you want.
Squeak/squeal could be a wheel bearing? Sounds like it is still within tolerance and normal operating behavior, unless it's a REALLY loud squeak. Just my thoughts.
Look at both wheel balance and possibly a bent rim on the shake issue. Or a internally torn tire belt with a patch job covering it over I suppose. Can also be worn tie rod ends, or worn suspension arms, likely the front upper ones on the inside bushing/mount point. Easy to inspect those control arm bushings.
Also, look at spark plug change (and air filter) from what you describe if they haven't been changed recently, and definitely a bottle or two of Techron (cheapest, easiest thing to try of all).
Look at CV joints in general too. As a 2001, the boots are likely torn by now unless previously changed, usually the outer fronts. Could fit into your noise, but even if its a wheel bearing, a chance to address both ills at once and with a lot of related labor steps.
Is the CEL on? Have you pulled codes from both the engine and transmission?
Thanks man. Very informative reply there. Will keep it all in mind.
The CEL is not on.
