what oil would you recommend - 3.0 with 130k miles
I think it uses/burns a little oil now but not bad for the mileage of 131k.
I did not bring the owners manual to my office, I think it was 6qts - going to stop and buy some oil and filter on the way home.
Which is just fine - a bit of extra ZDDP which is never a bad thing, and an HTHS of 4.0, also a good thing.
Truth is i dont think on a normally driven car it makes all that much difference.
The 3.0s wear badly, so i'd use an oil with good wear properties and would not leave it in for the duration - maybe 5-6k (if a good synthetic, half that if not).
G
G
No, M1 0w40 is a good oil,but not one of my preferred ones, for reasons noted below.
I agree that many of the new specs are ill advised. They are designed to promote very long drain intervals, whcih have been proven to not work as intended (Toyota, VW, and Porsche all rescinded theirs after sludge and/or wear issues). Further, the low zddp is intended to reduce damage to the cats. But if a motor does not burn substantial oil, no (well, in practice, minimal) zddp gets to the cats anyway. So that's mis-aimed.
But back to the point, the HM oils are, by definition, aimed at out of warranty cars, and need pay no heed to the specs.
I'll also point out that for wear, the two approvals to look for are:
ACEA A3/B4 - Hths > 3.6, and
Porsche approval, which implies ACEA A3/B4 plus some proprietary wear tests
Finally, all should remember that oil is a large series of trade-offs. Thick (good wear at high temp) is not "good" - rather it favors hard, hot operation over cold flow.
Wide ranges (e.g.: 0w60, 0w40) appear to be best of all worlds, but are not. They require modifiers and break down, creating more sludge producing materials than would otherwise exist, AND shearing to a lower grade - nullifying the reason for their very existence. Pass.
G
G
1. the flash point (high temp stability), and
2. The long term stability / shear down, which will lower both hths and flash
That's where most non-synthetics fall down. Change more frequently.
Valvoline however has a long history of dealing with turbo cars. Back in the early 80s they had the first turbo specific motor oil, Valvoline Turbo V ( a 15w50 as i recall) designed to have a high temp stability and low incidence of coking.
Of course, its also best to cool down your turbos - then you dont need "superoil".
G
