i need some help just picked up a 2000 TT for $1400
Old Mar 24, 2012 | 03:25 AM
Troy Flater's Avatar
Default i need some help just picked up a 2000 TT for $1400
hello there everyone,
2000 Audi TT 140k on it.
I used to have a 2000 and 2001 GTI. I had a friend of mine work on them. Unfortunately he is not alive anymore due to the BS in IRAQ. I am not a mechanic but i know some things. I am looking for some people around Central Wisconsin to give me a hand to get the car running up to par. Not modified yet until it runs runs the way it suppose too stock.
Problems with car:
One hell of a mess on the vaccuum lines. I even found PVC piping in the car.( I will take pics of the car later today.
It has some kind of generic cold air intake and filter. Dc sports exhaust that is very loud. Car falls flat on its face when it reaches 4500+ rpm. I am not driving the car until its fixed.
(I will probably be selling the rims. they are Oz ultra 17's black)
the car runs and drives ok until it hits 4500 rpm.
I look forward to being a member of this forum
thanks,
Troy
Old Mar 24, 2012 | 09:45 AM
bearshort's Avatar
Problems with car:
thanks,
Troy
Troy, are you getting any kind of check engine signal?
Old Mar 24, 2012 | 09:50 AM
bearshort's Avatar
From a quick search, I would first check for leaks.
Then, try cleaning/replacing your MAF (http://www.wak-tt.com/maf/maf.htm), Diverter Valve, and N75, in order. Someone else suggested disconnecting the MAF and seeing if it drives smother.
Probably need to provide a bit more info. Besides loss of power, getting any noises? Perhaps the coil pack?
Old Mar 25, 2012 | 08:03 PM
Default I figuired some things out
I found a manual boost controller connected.
Took it off and the car runs way better but not quite the way it should. 5 psi of boost only. It does not fall on its face at 4500+rpm anymore. I know it has to do with a boost leak now. its got to be the piping. (its a mess and a joke.) I am looking for a hard pipe setup reasonably priced. perhaps some one can lead me in the right direction. I dont know much about where to find parts. Also found out it has a Ko4s turbo of some sort on it. I found the receipt no more then 5000 miles ago from previous owner. I cannot wait to get this running right. Also not I have a set of aftermarket side skirts and rear bumper cover for dual outlet exhaust. I will sell. just message me
Old Mar 30, 2012 | 08:22 PM
well what a mess... I need to find someone in Wisconsin Area to help me with this car. I have no more cut off at 4500 rpm.
I found a diagragm but i dont think i have it correct yet.
i found out the secondary injection pump is not in there but the N249 and N112 is still there. the hoses to them are plugged off.
the crankcase ventilation hose is plugged.
the combination valve is still in there.
what i changed was put the acuator to the N75
and the other line to the N75 to the pipe that goes to the intercooler.
The car boosts at only 5 psi.
Some idiot that said he knew what he was doing adjusted the actuator on the turbo and now it takes quite a while for it to boost.
he teed off the hose that in the intake to the divertor valve.
someone please give me some ideas how to fix this car.
again this is a mess..
thanks,
Old Apr 1, 2012 | 10:51 AM
EGRoadster's Avatar
Troy, take lots of pics, and keep posting for help. One subject at a time. Be prepared that this puzzle will take a while to sort out. But it will be a great project. Your buddy will be proud, even that he is not with us. Let us take it step by step. And let us get the car back to stock form.
You will need VAGCOM, and the Bentley manual, tools, time, and the right attitude. I have been there, I sorted out a 2000 APX European TT, and it was a nightmare. Now, it is a champion :-)
I have a good doc (TTweakers guide), if you e-mail me I can send it to you.
Get an account with http://genuineaudiparts.com/partloca...?siteid=214407 , it will make getting parts a little bit easier/cheaper.
Now then:
1-Is the intake clean and in good shape?
2-Is the MAF working? Check block 32, TTWeakers has some hints.
3-Is N75 hooked up properly? It has 3 hoses. Boost, wastegate, and intake.
4-Is the PCV hooked up properly? This lets vapors escape from the crankcase, and valve cover.
5-Is the SAI hooked up properly?
6-Is the N249 hooked up properly?
7-Is the DV hooked up properly? It looks like someone did a DV relocation, which is a fine mod.
8-Is the EVAP system hooked up properly?
9-Are all the check valves in place?
10-Identify your turbo:
http://audittmk1.blogspot.com/2008/0...s-k04-etc.html
11-Check your ignition (coils and plugs are good?)
12-All valves, sensors and solenoids good? EVAP Solenoid, N249 Solenoid, PCV valve, SAI valve, AIT, CTS, 02.
13-Cooling working well? Fans, condenser, radiator, inter cooler
14-No electric faults, relays, fuses, wires are good?
Sadly, there are lots of mods out there, and changes, that should only be done if you have a big turbo, or know what you are doing. It is sad, on the other hand, you can reliably make a 1.8T sing. Let's do this.
Old Apr 9, 2012 | 04:01 PM
Default I finally found out that my car is throwing codes
P0106
P0134
P0102
P1335
P0238
I have looked up a few of these. I have no idea what i am doing.
Previous owner of car took out the SAI on it. Also the car has a K04-001 turbo (less then 3 miles on it)
Old Apr 11, 2012 | 05:25 PM
Rahl2323's Avatar
Default Here to help.
Hey Troy, where in Wisconsin are you located anywhere near Eau Claire? I had the same type of issues with my car and I re routed and replaced all vacuum hoses and problem is gone! I also have Vag-Com if you are in the area!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 13, 2012 | 09:57 AM
EGRoadster's Avatar
Default Is it a 180 or 225
If it has a k04-001, then is is a 180hp TT, with an ATC engine. While the k04-001 is a bolt on, you need good software to make the most of it. Speaking of software, any idea what tune you are running?
Now let us look at the codes:
16490 Manifold Abs.Pressure or Bar.Pressure Range/Performance
16486 Mass or Volume Air Flow Circ Low Input
16622 Turbocharger Boost Sensor (A) Circ High Input
17743 Engine Torque Monitoring 2 Control Limit Exceeded
16518 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
First, if you clear them, do they come back?
Next, check your MAF, and MAP sensors. Using VAG-COM do some data logging and see if they deliver accurate readings. Also, try to run the car without the MAF, if it runs better, your MAF is dead.
From these codes, the MAP sensor is a strong suspect. Does it have a resistor mod? Is it plugged properly?
On the other hand, your O2 sensor is also not happy. Again, do some logs (with and without the MAF plugged) and see how it behaves.
Put the SAI back on if you can. It will help get the car back to stock form.
Avoid a brute approach of replacing the MAP, MAF and 02 all at once. Test each and make sure they're good/bad first.
Old Apr 13, 2012 | 10:23 AM
misternoob's Avatar
Copied from VWVortex. Hope it helps.
Originally Posted by groggory
Testing the MAF, o2 Sensors, and Catalytic Converter
In order to test your MAF, O2 sensors and catalytic converter, check out the following blocks in the "Engine" control module with your VAG-COM. Blocks 002, 030, 032 and 033 are done in "Measuring Blocks" while blocks 036, 034 and 046 are done in "Basic Settings". Let me know if you have any questions about how to run the tests. (<I>NOTE:</I> The following tests are MKIV VR6 specific. If you have a 1.8T or 2.0 engine, the procedure from running the automated tests is slightly different. For a 1.8T engine, see this <A HREF="http://forums.vwvortex.com/zerothread?id=1672645" TARGET="_blank">THREAD</A> for instructions on how to initiate the tests. I'm not positive about the initiation procedure with a 2.0 engine, but from what I've found, with an AEG engine you manually raise the engine speed to between 1800 and 2200 RPMs, and with the AVH and AZG engines, you derpress the accelerator to the WOT (wide open throttle) position to raise the engine speed to ~2000 RPMs.<p><br><B>Block 002 - Load Registration</B><p> - Check the MAF airflow reading at idle. Make sure the car is running and warmed up and the A/C is off. Go to Block 002 and look in Field 4. The value at idle should be between 1 and 25 g/s. If it's lower than 1 g/s, then there is probably a leak in the intake tubing between the MAF and manifold.<p><br><B>Block 030 - Oxygen Sensor Regulation</B><p> - Go to Block 030. Field 1 is a three-digit binary code which gives the status of the pre-cat oxygen sensor. Field 2 is the same thing but for the post-cat oxygen sensor. The digits indicate whether or not the sensor heater is working and whether or not the oxygen sensor control is operational and active. The value should fluctuate between 111 (heater on) and 011 (heater off). The last two digits can also fluctuate between '1' and '0', but should be predominantly '1'.<p><br><B>Block 032 - Oxygen Sensor Control Learned Values</B><p> - Go to Block 032. Field 1 represents the fuel trim at idle (additive) and Field 2 represents the fuel trim at part load (multiplicative), i.e., while driving. The value should be between -10 and +10% (negative indicates the engine is running rich and positive indicates the engine is running lean). If the value is close to +25% (which is the upper limit), it usually means that the MAF is bad. If the value is somewhere betweeen +10 and +25%, it could mean that the pre-cat oxygen sensor is bad, there is a leak in the intake or that the MAF is on it's way out. The value I found for my car (VR6), which has a new 2.0 MAF and new oxygen sensors is +1.6%.<p><br><B>Block 033 - Pre-Cat Oxygen Sensor Control</B><p> - Go to Block 033. The value in Field 1 represents the pre-cat oxygen sensor control. The value should fluctuate at least 2% in the -10 to +10% range.<p><br><B>Block 036 - Post-Cat Oxygen Sensor Control</B><p> - Go to Block 036 (this test must be done in basic settings, not measuring blocks). Depress and hold brake pedal to run the automated test. The engine RPMs should raise to around 1400. Field 1 is post-cat sensor voltage. It must fluctuate slightly between 0 and 1V. Field 4 will say either 'TEST OFF/ON' before/while the test is running and either 'B1-S2 OK' (sensor is good) or 'B1-S2 NOT OK' (sensor is bad) after the test is finished. Release the brake pedal after the test finishes.<p><br><B>Block 034 - Aging of Pre-Cat Oxygen Sensor</B><p> - Go to Block 034 (this test must be done in basic settings, not measuring blocks). Depress and hold brake pedal to run the automated test. The engine RPMs should raise to around 1400. Field 1 is the engine speed. Field 2 is the catalytic converter temp. Field 3 is the value which tells you how aged the sensor is (not sure what it's called). Field 4 will say either 'TEST OFF/ON' before/while the test is running and either 'B1-S1 OK' or 'B1-S1 NOT OK' after the test is finished. The aging value must be above 0.80. The value for a new sensor is 1.99. The value will decrease as the sensor ages. Release the brake pedal after the test finishes.<p><br><B>Block 046 - Catalytic Converter</B><p>NOTE: The test in Block 034 must be done just before this test or it will NOT initiate!<p> - Go to Block 046 (this test must be done in basic settings, not measuring blocks). Depress and hold brake pedal to start the automated cat. test (last approx. 100 secs - the cat needs to be warmed up above a certain threshold for an accurate reading - the threshold is usually 400°C). The engine RPMs (Field 1) should raise to around 1400. Field 2 is the cat. temp. This will also rise during the test. Field 3 is the cat. conversion efficiency. If the cat is good, the value should be below 0.50 at the end of the test. Field 4 will indicate if the cat is good (CAT B1 - OK) or bad (CAT B1 - NOT OK). Release the brake pedal after the test finishes.
