Motor oil ran low...
I want to know if this is normal for this car? If so, how often will it be low. Also, will I still need regular oil changes after filling up with the new motor oil.
I am a new Audi car driver so bare with me on these questions.
Thanks.
the best question to you would be when did you do a oil change or last check the level before this happened?
Do you never check your oil? 2 quarts down is a LOT - at least some damage will be done if you run a car that low.
Technically, Audi's spec is 1 qt/1000 mi. But my last 2 cars burn essentially zero - i need not top it off (not even 1/4 qt) in 5-7k changes, which are essentially annual.
So there is significant variability, based on manufacturing variation, how the car was broken in, and wear.
G
