What is the popping at the top of the RPM band
www.youtube.com/watch?v=UtyxBVP5s1o[/url]
What is all that smoke coming out? Does seafoam do that?
If so, why would anyone use it?
You should never rev a motor until it is warmed up. Oil does not flow properly, and parts don't have the operating fit - they expand when hot.
G
Which in fact i did right before this. because another was to use the seafoam is you pour 1 can in your gas tank, (fuel injectors..
and you pour some in the oil. ( that is not where the smoke is coming from but has the same cleaning effect.) And where the smoke came from is i pulled a vac hose off of the intake manifold and slowly let the seafoam be sucked into the manifold. Turn off the motor for about 5-10 min, then clear as shown in the video
The problem with physical methods (and some of seafoam is physical thermal shock) is that the operation often breaks of larger chunks of carbon/deposits that can clog the catalytic converter. Techron or gas with techrolene and the nitrogen Shell additive package doesn't do that.
I've found that using a gasoline that meets Top Tier specifications eliminates the carbon buildup problem.
http://www.toptiergas.com/
Today, i would have a vacuum hose suck a little in through a needle, just as some turbo kits do to quell predetonation.
I'm still passing on funny stuff that generates prodigious smoke.
G
And the smoke only exists for such a short while there is no adverse effects, like prolonged smoking. or else it Would be a deal breaker.
John, Your comment prompted me to do some digging.
http://www.newsnet5.com/dpp/news/loc...s-for-your-car
