2001 4.2 - 235 45/17 vs. 245 45/17
Thanks in advance..!
I like conti DW tires, good price for performance.
Having a sport suspension, the slight softening was OK with me. After nearly 2.5 years and nearly 25K miles, I think there may be another 10K or so left on them. Obviously, I don't drive the car very hard...but a quick 2nd gear pull now and then keeps my ya-ya's grinning for a while.
I also recommend road-force balancing.
Meanwhile, remember RS6's run 255/40 18, which diameter wise is similar to 255/45 17. I have run the RS6 OEM wheels with the stock 18's (Dunlop 9000's) on my 4.2, hence know of the speedo. No obvious differences in braking, handling, ride, mileage.
From 40 to 45--which I have also experimented w in 17's--little difference in ride comfort, which surprised me a bit.
No clearance issues w/ any of these on OEM wheels, and obviously it closes up some fender gap. The RS6 wheels are 8 1/2's, though at ET30 instead of ET35 on the 8" 4.2 17's, the tire edge lands just about the same relative to the fenders. Mine is non-sport as built, though I switched to S6 bars and recently finally installed the Bilstein HD's I ordered years ago. Ride height remains stock.
All will be quite small.
G
OTOH, the 255/40R17 on my 02S6 read exact at 60mph according to my radar gun....so a couple mph there would put me over the speed limit or within range of a 12mph grace if I'm pushing 10 over....
10mm isn't much for summer, but 20mm is significantly narrower. I run 235s in the winter tire size.
Why do you think we use wider tires? If not we'd all be on 110/200-17s.
The other fallacy that we can fall into is that friction = F*c(f). In its basic definition, friction has nothing to do with area. Clearly this is wrong, w/r/t cars (or we're all really suckers, including those dumb-*** F1 teams and all their Hoyt-toity PhDs). The secret is that friction is not the limiting factor in 99.9% of dry adhesion - shear is. And more rubber = less shear.
Simple physics is simplistic. Actually, i was thrilled to see these used by Prof Lewin as fun examples in 8.01 (Classical Mechanics at MIT), since i had thought about the conundrum earlier (even asked Ross Bentley about it)
G
http://www.miata.net/garage/tirecalc.html
