A6 with possible cat problems
I have a 2002 a6 and my CEL has been off and on for a couple months now. I hooked it up to my VAG-COM and the only possible codes I am reading that I could believe to cause it are these:
2 Faults Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-10 - Efficiency Below Threshold - Intermittent
I figure it was a o2 sensor but was wondering if anyone around here had any insight on pinpointing which ones are bad and if it could be anything other than the o2 sensors.
All help is appreciated.
Thanks!
But it hasn't been running any worse which is why i wasn't suspecting the cats to be the problem. If you could elaborate more on that?
If not, $100 for 2x O2 Simulator, mini cat
Most think Audi spec is too narrow to throw the CEL. Both cat go wrong at same time is not that usual. What you need to get the light off.
Jim
