TTSecondary Air Injection Rough Idle
Old Apr 10, 2012 | 07:43 AM
gustapus's Avatar
Default TTSecondary Air Injection Rough Idle
I have a 2001 TT Mk.1 convertible/roadster with the 1.8L engine. On a cold start, when the secondary air injection (SAI) pump kicks in, the engine idle increases (as it should) but the engine starts to idle roughly, with one or the other (usually #3 or #4) cylinders misfiring. As soon as the SAI pump kicks off, the engine idles perfectly. Sometimes it sets a Check Engine Light (CEL) with a cylinder mis-fire code, sometimes not, depending on how long the cold/SAI idle continues. It had the ignition coil campaign performed a number of years ago. The SAI associated tubing has been replaced/checked recently by an Audi mechanic. I have a MAF sensor in transit, and replaced the (apparently) never-changed-since-new fuel filter. I have new coils also in transit. But I fear I'm missing something and just "replacing with known good components". Oxygen sensor, maybe? Which one? If anybody else has had this problem, I would appreciate some insight. Help, please!
Old Apr 10, 2012 | 12:51 PM
Prospeeder's Avatar
Swap the coils from #1 and 2 to #3 and 4 and see if the miss follows when this happens. If it does, obviously bad coils. So this car wouldnt happen to have some kind of modified intake, or a cone filter or anything. If somebody put the intake tube from the Air injection pump after the maf sensor that would cause an insane air leak when the pump turns on and the SAI valves open. Making it run awful and miss. Some shop could have even routed the connection wrong for breather stuff. It can all look like kind of a mess of hoses on some models of 1.8T
audifirst
30v V6 Discussion
12
Jun 27, 2013 02:04 PM
gotbanned
Dec 3, 2010 05:09 AM
matrixabc
Oct 7, 2003 10:50 AM
Ajagdfeld
Audi 100 / A6 (C4 Platform)
May 1, 2002 12:15 PM
